I would expect the manual to coast a little farther in gear because it wouldn't be so slippy as an automatic, but on neutral the difference might be negligible.
Originally Posted by California98Civic
Where does the auto trans fluid pump get its power? Is it a parasitic load on the trans directly, indirectly via the engine, or more indirectly via some electrical system drawing on the battery?
I have never seen an electric ATF pump.
