Old 06-09-2014, 09:28 AM   #2 (permalink)
Xist
It says that you have six posts, so you should be able to share pictures. We can only help you so much otherwise, although I would think that by only working with the air between the wheels, your are limiting the effectiveness. If you had spats in front of the wheels, directing the air around, that should work better.
