ecomodded, I too was surprised when I found out it was going into OD and not 4th. I have only had this car a few weeks, so it is still taking some time to get use to it. Also this is my first diesel I can run torque with, so I can start to understand what works best.
Goldenstate, Do you watch the load or throttle when you take off? If so, have you found what works best for you (ie mid throttle/load or high)?
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
