Well like i said i do have two are damns installed..Now i just need to post the pics of them to give everyone an idea what they look like. Just as an opinion..Do you think 40psi is too high for the front tires..I already know the ride quality it has and when the air expands when its hot the tires show from the dirt on them that you can actualy see how much the contact the tire has on the road as the edges are clean and not touching...This is when they are set to 40 psi cold and then driven on. They go up to like 46 or 47 psi hot.
