Im running Good Year Wrangler Authority which i do believe are 31s. Stock would have been 28.They are rated at the max sidewall psi of 50. They are a LT (Light Truck Tire) All Terrain type. And id say they have a decently stiff sidewall to begin with. I had a leak on one of the old tires it used to have on it of the same size called Wildcats All Terrain. The one leaked so bad from a huge roofing nail i went to 0psi over night and the sidewall of the tire still held it up considerably. You could only tell by a little bit that it seemed low. lol So i'm thinking the tires i have on now have an equally stiff sidewall. But its probably besides the point. Yes the sidewall of the tire say 50 psi max. I also don't want to reduce my braking distance too much neither.
