Old 06-10-2014, 06:07 PM   #1 (permalink)
bs25942
A.J. - '04 Honda Civic LX
90 day: 41.47 mpg (US)
bruce - '08 Kawasaki Ninja 650 R
90 day: 46.52 mpg (US)
Big Blue - '09 Ford F-150 LX
90 day: 17.33 mpg (US)
dr - '13 Kawasaki DR650
90 day: 55.32 mpg (US)
Boat Tail Construction-Civic Sedan
After viewing the 'redneck boat tail' I have decided to make a boat tail. I have overlayed the template on images and they seem alright. Can anyone tell me if they are wrong in an way? I was not sure if the side taper was done correctly.
For materials,
I will probably build the frame as a tubular structure. I was thinking Metal conduit or PVC piping? For anyone with PVC experience, do you think it would be strong enough to support the weight? This seems easier since I can use a heat gun and bend it to the right shape.
I want to build the frame and then cover it in foam. After sanding/filing the foam, I want to fiberglass it with probably two layers of 4 oz cloth. Does this sound reasonable?
For the rear section, I will probably use 10mm coroplast that I have lying around.
Please give suggestions and point out problems if you can
Name:	AJ side donex small.jpg
ID:	15173   Click image for larger version
Name:	AJ final top small.jpg
