Originally Posted by mcbota
I try to use the same briskly method of acceleration, since I have discovered this website, but I cannot understand how can be done this under the 2000 rpm. If I have to use around 80% throttle method, then I will reach around 2800 rpm, before I will change the gear, because I cannot accelerate briskly starting form low rpm! So how do I have to do?
That is the same for me. The EX has higher rpms than other models of civic.
I just watch the % engine load, speed, instant and trip mpg.
