06-11-2014, 10:23 AM
#11 (permalink)
Cobb, I still drive like an old man to a point, I take off hard, but still only do about 49 in a 55. I found that my OBD reader shows 40-45mpg at 55, but shows 50-55mpg at 48.
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
06-12-2014, 06:04 AM
#12 (permalink)
Originally Posted by Rango318
oldtamiyaphile, I'll keep that in consideration. I figure even if it isn't the most accurate, I still have something to look at and keep me motivated to get better numbers.
I just filled up my 4th tank on my TDi, my first tanks were my usual foot to the floor approach, which netted me 9l/100km.
On the third tank I went with the 80% load method (which is really slow in my case), SGII promised 8.4l/100km, but the fill up was a disapointing 9. My best to worst tank so far have only been 0.2 apart.
If I can't evaluate different driving styles with it, SG and others are of limited use as a diesel saving device IMO.
06-12-2014, 09:08 AM
#13 (permalink)
It seems you are also getting the turbo spoiled up higher which helps mpg.
It is critical that if you eco drive a diesel that it gets a good hard "Italian tune up" regularly to keep the VNT from freezing up.
06-12-2014, 12:19 PM
#14 (permalink)
JasonG, I have never heard of an Italian tune up, so i had to look it up. Took me straight to TDIforum. That seems to be about how I drive now so I'll just keep doing it. I know my Torque app isn't correct, but I like seeing 53mpg on my 26 mile drive home from work.
06-12-2014, 02:14 PM
#15 (permalink)
I try to use the same briskly method of acceleration, since I have discovered this website, but I cannot understand how can be done this under the 2000 rpm. If I have to use around 80% throttle method, then I will reach around 2800 rpm, before I will change the gear, because I cannot accelerate briskly starting form low rpm! So how do I have to do?
06-12-2014, 02:21 PM
#16 (permalink)
Mcbota, when I accelerate, I don't keep it under 2000 rpms when I am driving this way. My car usually shifts around 3.5k-3.8k under hard take off. If I am taking off slowly, the way I use to, it would shift around d 2k.
The Following User Says Thank You to Rango318 For This Useful Post:
06-12-2014, 02:43 PM
#17 (permalink)
I was thinking that even if I have to do briskly/hard acceleration, some are saying to not go above 200rpm, and I didnt understand how is this possible!)))
06-12-2014, 03:39 PM
#18 (permalink)
Drive less save more
My car makes full torque at 1900rpm so 80% load is somewhere under that.
I have a fuel pump tuning box hooked up between my fuel pump and ECU that gives my car snappy acceleration , making the 1st 1/2" of throttle powerful & energetic on my tdi.
Shift fast , stay in each gear for 2 seconds or so.
Save gas
06-12-2014, 03:56 PM
#19 (permalink)
I have made also a chiptuning to my car, an economical one, but I am afraid to accelerate briskly under 1800 rpm, to not provoke some lugging!
06-12-2014, 05:38 PM
#20 (permalink)
Liberty Lover
That is the same for me. The EX has higher rpms than other models of civic.
I just watch the % engine load, speed, instant and trip mpg.
