Only partially completed puncturing the aluminum. The negative to getting thicker aluminum is having to
puncture thicker aluminum.
The joints welds (JB Weld on the threading, then the pipes screwed in) has held very well, there is no movement- I then used more on the exterior. Realized I didn't take as many images as I should have. 9 punctures left for the main frame, then the punctures for the rear portion.
After that, I will making the blades down to help direct the air.
![](https://lh3.googleusercontent.com/--77kRMl5zGU/U5ue5BiaquI/AAAAAAAALgk/GHCpSzVirdc/w1783-h1004-no/IMG_20140613_210053181.jpg)
