Old 06-14-2014, 12:53 AM   #129 (permalink)
freebeard
Go by what he meant not what he said...
"Was it over when the Germans bombed Pearl Harbor?"
(with a wierd rim it could fit my old diesel suburban though (barely) Has anyone determined what the weight ratings of these tires are? What are the inflation pressures?
It would take 8 of them to hold up a Suburban; they're for the BMW i3.
03-12-2013, 03:17 PM #23 (permalink)
rmay635703
I still rather have 155/90 r12/13/14 or 15
You were in the thread in March, have you followed along since? All this back and forth about bumps and energy absorbed by the suspension ignores the fact that a key design feature is using a high-profile aspect ratio so higher pressures can be run.
Centerline can make a wheel in any diameter, offset and bolt pattern you require. All the 19x4s have long since left the junkyards, try swap meets.
