Old 06-14-2014, 05:48 PM   #197 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Re building undertray version 2.0 (rear)
Started building the rear portion of the undertray. Got underneath the car to find some mounting points.
Found some where the rear bumper bolts into the chassis
Measured the distance between the two holes to make a cross bar for the tray to bolt onto
Now I gotta connect the middle tray to the rear bumper, however the rear lower control arm is in the way. So I bent the aluminum bar for clearance.
Here is the clearance for the rear lower control arm, hopefully it's enough for the control arm to move naturally without banging on the aluminum bar.
Drilled some holes to bolt the tray onto
Drilled some holes onto the rear portion of the middle frame so I can connect the rear aluminum bar
Here is the bar bolted onto the rear bumper cross bar
Here is another shot of the cutout for the exhaust pipe
And the finished product!
Starting to cut out the actual undertray. It's 6mm coroplast, very sturdy, but also heavier than 4mm. It's harder to cut too!
Next up, bolting the tray to the frame.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
Eastwood (06-14-2014)
