Originally Posted by sarguy01
Not true. I put new bushings on my control arms and my alignment is a bit off.
Well something is buggered up because it is not part of the alignment adjustments unless they are adjustable, stock ones are not.
I have done this work to vehicles both with adjustable control arms which you adjust the length of each one and the easy as pie non adjustable stock ones that you just swap.
So when you replace the control arm the ONLY possible change would be the position left side to right side of the axle/axles, so its centered under the car.
that's it.
