Originally Posted by Cobb
How does it drive? Maybe vtec is stuck in the engaged position? Maybe previous owner put another cam in it or did engine work? Maybe the engine is toast? Have you done a compression check?
Its a D15b7, non vtec, no compression test done yet. I did however notice that it needs an alignment. would it be significant enough to kill my gas milage so much?
