Old 06-14-2014, 08:29 PM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the best is 31 and the worst is 25mpg for the 4 models.
go to tire rack dot com
FInd out the STOCK size tire.
find its diameter.
See how your diameter compares.
you might be smaller so your turning more rpms
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-14-2014, 08:30 PM   #12 (permalink)
Originally Posted by mcrews View Post
1993 HONDA CIVIC DEL SOL
City
28 mpg (8.4 litres/100km)
Hwy
35 mpg (6.7 litres/100km)
Combined
31 mpg (7.6 litres/100km)
Yearly Fuel Cost
$500
Figures adjusted for EPA's new 2008 estimation method.
Class
TWO SEATERS
Engine
4 cyl. 91 cubic inches (1.5 litres)
Transmission
Manual Five-Speed
Fuel
Regular Gasoline
City
25 mpg (9.4 litres/100km)
Hwy
33 mpg (7.1 litres/100km)
Combined
29 mpg (8.1 litres/100km)
Yearly Fuel Cost
$545
Class
TWO SEATERS
Engine
Transmission
Lock-Up/Automatic/4-Speed
Fuel
Regular Gasoline
City
24 mpg (9.8 litres/100km)
Hwy
30 mpg (7.8 litres/100km)
Combined
27 mpg (8.7 litres/100km)
Yearly Fuel Cost
$581
Class
TWO SEATERS
Engine
4 cyl. 97 cubic inches (1.6 litres)
Transmission
Manual Five-Speed
Fuel
Regular Gasoline
City
23 mpg (10.2 litres/100km)
Hwy
Combined
Yearly Fuel Cost
$621
Class
TWO SEATERS
Engine
Transmission
Fuel
Regular Gasoline
Idk if i should just sell it and look for a CRX, or try to improve the mpg
Old 06-14-2014, 08:32 PM   #13 (permalink)
find its diameter.
thanks for the advice! i really appreciate it.. with my mpgs i should've bought a V8 lol. I didn't realize smaller rims made the RPMs turn faster!
Old 06-14-2014, 08:37 PM   #14 (permalink)
mcrews's Avatar
not necessarily smaller rims.......but smaller diameter tires
it's all about the final diameter of the TIRE.
on 18 inch rims stock was 245/45/18.
I went with a taller tire on the stock rim 245/55/18 and got a 6% larger diameter tire that still fit. It lowered my rpms on the road and helped me get 32+mpg in an 02 Infiniti Q45!
never did anything to the engine....
ECO MODS PERFORMED:
First: ScangaugeII
Old 06-14-2014, 08:45 PM   #15 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by D.Sol View Post
Is that a good motor+transmission to work with for great mpgs?
Yeah, you have the 0.702 fifth gear and the 4.058 final drive, which is a little better than the Del Sol Si and a couple others. It's about the same gearing as alot of the DX and LX trims had, fifth and sixth generations. The engine too is fun, because it does not have any of the vtec features, which at this point are aging and becoming difficult and costly to get some parts for, like the all-important wideband O2 sensors and exhaust manis and CATs.
Awesome platform for good, economical ecomod motoring. I love the look of that little car, personally.
Old 06-14-2014, 08:48 PM   #16 (permalink)
Cyborg ECU
find its diameter.
I compiled that information from service manuals: http://ecomodder.com/forum/showthrea...tml#post378478
Old 06-14-2014, 09:46 PM   #17 (permalink)
How does it drive? Maybe vtec is stuck in the engaged position? Maybe previous owner put another cam in it or did engine work? Maybe the engine is toast? Have you done a compression check?
Old 06-14-2014, 10:04 PM   #18 (permalink)
backpacker3's Avatar
Homer - '02 Pontiac Sunfire SE
Team Pontiac
90 day: 30.05 mpg (US)
I'm going to ask what might be a stupid question but is there any maintenance that needs to be done? Plugs, wires, belts, fluids, etc. you probably have but every now and again you find someone who hasn't or sometimes a spark plug is bad and just needs to be replaced even if it is newer. I was just talking to someone the other day who said they don't change or even check their transmission fluid because they (and I quote) "were told that you don't need to because it's just a scam and you never should do anything to the transmission because that's just going to wreck it. You don't even need to fix it if it breaks because you're better off with a whole new transmission anyway"
At that point I understood why they were having transmission problems in their car.
Old 06-14-2014, 10:07 PM   #19 (permalink)
Its a D15b7, non vtec, no compression test done yet. I did however notice that it needs an alignment. would it be significant enough to kill my gas milage so much?
The Following User Says Thank You to D.Sol For This Useful Post:
Cobb (06-15-2014)
Old 06-14-2014, 10:12 PM   #20 (permalink)
mcrews's Avatar
Originally Posted by backpacker3 View Post
I'm I was just talking to someone the other day who said they don't change or even check their transmission fluid because they (and I quote) "were told that you don't need to because it's just a scam and you never should do anything to the transmission because that's just going to wreck it. You don't even need to fix it if it breaks because you're better off with a whole new transmission anyway"
Put 270,000 miles on the Infiniti Q45 w/ a sealed transmission.
With that said, some cars might still have a filter and need to have the fluid changed. Others might not.
ECO MODS PERFORMED:
First: ScangaugeII
The Following User Says Thank You to mcrews For This Useful Post:
Cobb (06-15-2014)
