Old 06-15-2014, 09:39 AM   #176 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
You are talking about a fuse on the key switch? that fuse shouldn't need to be more then a 1 amp fuse but Alltrax says to use nothing larger then a 5 amp fuse, that connection on the controller doesn't draw much.
What are you going to do with the emergency cutoff switch? that switch does the same job as the key switch.
