Old 06-15-2014, 01:10 PM   #17 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Davo53209@yahoo.com View Post
What is the difference between a CX & VX exhaust manifold? So far, I've noticed that they have the same part number. Is there are significant difference?
The 1992-1995 CX did not have lean burn, so it did not have the wideband O2 sensor plugged in just ahread of the CAT in the exhaust minifold. But if you are correct and that part number is the same, then I've learned something too. I guess you could get the CX manifold and use it and still get lean burn because you'll have the wideband O2... have you checked to make sure it's the wideband O2? I think it is 5 wire instead of the 4 wire. I think.
