Originally Posted by Old Mechanic
I'll check with my body shop buddy. Here is a link to another possible source. The cat in the VX is as close asit can be to the exhaust port. I think that is because lean burn makes it necessary to keep the converter temperature high enough for it to work properly.
Catalytic Converters - Auto Parts Warehouse
regards
Mech
Do you think this aftermarket CAT will achieve the same mpg as an OEM part?
