I got this response from Facebook.
Hey Robert, we'll answer the questions that we can! It will weight about 1250 pounds. It will be able to be flat towed. The coefficient of drag is within the low to mid .2 range. That's all of the answers we can give right now.
I would say 1,250lbs is exceptional for 55hp. That's like my car having 84hp, which would be quite the improvement. 700lbs less weight, far smaller frontal area, acceptable aerodynamics. I can see how 84mpg highway would be realistic.
It sounds like it would be fun to drive from those specs. You could really throw it around corners, and mountain passes wouldn't be terrible. It should be a pleasant departure from the "beasts" the reservation holders are used to driving.
