It should be aligned to specs. The insight requires a zero toe, but that can cause some wiggles in windy weather. Since I am lowered I am -1 camber on both sides. This could be adjusted with camber bolts, but I rather keep it.
When you get alignment fill up gas tank and see if you can get a load that would be typical of you carrying.
