Old 06-20-2014, 02:38 PM   #84 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
What about machining a standard used sprocket to become a sprocket holder ?
Obviously your rear sprocket needs to be spaced the same.
Best economy is around peak torque AND at 75% throttle.
I would not fear about that 75% throttle thing because you still have 25% if needs be.
Waste mode is a personal naming that I give but basically it's away from peak torque and incidentally bikes are usually set up on the rich side at either side of the rpm for safety reasons.
