Old 06-21-2014, 02:00 PM   #25 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Baltothewolf View Post
I'm 100% sure it's oil, as the car was low on oil when I bought it, and I had to add some before I came home. The entire back of the engine is covered in oil and so is the underbelly. So yea.
Suspect the oil filter too. It is on the back of the engine. If it is not tight enough, if the gasket did not seal well because of... something, the oil will leak down the back of the engine. I solved an oil leak by removing the filter during a change and replacing it. Always run a little oil around the gasket with your finger before installing the filter.
