Old 06-21-2014, 01:11 PM   #88 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Ironside View Post
Although the fuel economy is important, the bike has to remain useable, having only 4 gears means that I dont have a spare gear to use as overdrive.
I've read somewhere that there is a vehicle called the TRX 125, which shares a similar motor but has 5 gears, if I could get one of those engines things might be different. Unfortunately it was never imported into the UK.
That was a 4-wheel ATV. Some had the Cub-type slant engine and others had a vertical-cylinder engine. Not sure if the slant-engine ones were ever available with a 5-speed transmission...
