Old 06-23-2014, 07:06 AM   #36 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by TimV View Post
when i need to slow down, i start early to let it in biggest gear until it is at 1300rpm, then i downshift 1 gear and so on...
Why do you downshift at 1300rpm? DFCO should continue until you reach idle. By keeping it in the highest gear/ lowest RPM, you minimize engine braking and maximize your distance traveled in DFCO .
I will often cruise in 5th at say 1300RPM, and if the light ahead changes, I'll shift up to 6th (~1000RPM), there's so little engine brake that it feels almost like neutral, but unlike neutral I'm using zero fuel. Once I feel/ see the fuel cut back in (800RPM) I just flick the lever into neutral and use the brakes to stop (traveling pretty slow at this stage). Sometimes I might go from 6th to 3rd during a stop to get a bit more DFCO and save the brakes, but I feel the extra wear & tear from the downshift isn't really worth the fuel saving.
Normally, the only time I downshift during DFCO is if the light changes and if I think I'll need say 3rd I'll downshift ASAP so I maximize DFCO and save brake wear, and of course I'm in the right gear when it's time to accelerate again.
