Old 06-23-2014, 11:36 AM   #43 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Old Mechanic View Post
I've drained hundreds of gallons of factory fill coolant out of Japanese cars. I know what it looks like. Stop by a Honda dealership and look at the coolant in the recovery bottle on anew car, that should convince you.
regards
Mech
I don't doubt that you know what the fluid looked like from the factory or at a Honda dealership, but I just bought coolant for my 1998 DX. I'm flushing my coolant system right now and I'm out there with the block tester checking for exhaust gasses in my coolant because I suspect the head gasket for replacement. O'Reilley's will tell you to buy the green, and that's what the shop put in 5 years ago when I had the radiator replaced. I realize the FSM calls for mixing Honda coolant with water 50/50 and that this might be that stuff. But unless we feel certain this is 14+ year old coolant (warranty), I'm suggesting that the coolant might be incorrectly replaced premixed stuff, for example using the orange/yellow or whatever, instead of the prescribed green. EDIT: just posted my test results: http://ecomodder.com/forum/showthrea...tml#post431456
