Old 06-23-2014, 11:49 AM   #133 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
"Test don't guess"
Originally Posted by johnlvs2run View Post
I don't know. I am curious because they didn't check mine.
I went back to the mantra of "test don't guess" and got a block tester to test for exhaust gasses in my coolant. Warmed the engine running some necessary errands, then let it sit in the driveway until the fan turned on automatically twice. Drained enough coolant with a dropper to prevent contaminating coolant from getting into the tester. Pumped the hand pump gently maybe 7 or 10 times, watching the bubbles run through the filter thing. Here are the results:
Blue fluid means no exhaust gasses present. My head gasket is fine.
If the head gasket were leaking, exhaust gasses would turn this blue fluid yellow. There is no head gasket leak. For the cost of $7 in testing, I saved maybe $40 on the replacement head gasket. And of course the labor. And the risk of messing up the factory job, which is apparently still very good.
EDIT: And thanks johnluvstorun for the question that made me explore whether my head gasket conclusion was warranted. It was not. Hahaha! "Test, don't guess."
Last edited by California98Civic; 06-23-2014 at 09:05 PM.. Reason: the head gasket was $40, not $100
The Following 6 Users Say Thank You to California98Civic For This Useful Post:
aerohead (08-23-2014), darcane (06-23-2014), deejaaa (06-23-2014), j12piprius (06-23-2014), jedi_sol (06-23-2014), user removed (06-23-2014)
