Originally Posted by Cobb
Hondas have an additional voltage or load regulator to help in fuel economy. They call it the ELD, it turns the alt on when battery voltage falls below 12.6 volts. I dont know the upper voltage, but think its near 13.8 to 14 volts. It trys to make the starter battery bare the load of the electrical system vs constantly powering the car by the alt. Theres plenty of stuff online how to disable it.
if its suppose to work this way thats fine its just trying to find people that know this so we what is a problem and not? so how do you troubleshoot this? and how low is to low? is the eld same as resistor block?
and i found this from another forum -
http://www.civicforums.com/forums/21...-detector.html
