Old 06-25-2014, 12:50 AM   #19 (permalink)
83gs1100g
83gs1100g's Avatar
Originally Posted by DOFZO View Post
You are somehow imagining a "spike" in power because of the engagement of the additional valve. There's no spike. You AREN'T going from 10hp with 12 valves to 92hp with 16 valve. You are just ABLE to get to 92hp (at 5500 rpm) because you have 16 valves. LOOK AT A D15B8. It only has 8 valves, but I bet if you were to "drag race" a CX off the line it would be an even race until you went above 2500 rpm where you would SLOWY pull ahead..
i know its not going to spike in power. what gave you that idea? what i am referring to is you will feel what is like when the a/c kicks on and off. that suttle change in power is the same as L/B engaging and disengaging. the shift light is my gauge for when L/b kicks in and out. when shift light comes on L/B will engage if you stay easy on throttle. my buddy has one and he says he cant tell when his L/b kicks in and out. so i drove it and i can tell. its very similar to a/c kicking on and off..[/QUOTE]
