Originally Posted by 83gs1100g
ok what happens here? the car is cold and you start it and take off will the motor go into L/B?
The default "mode" is L/B (12 valves). You have four conditions to meet in order to exit L/B "mode" (16 valves).
For 16 valve operations, all four conditions have to be met:
-Minimum engine speed: 2500 rpm. (NOT IDLE)
-Minimum vehicle speed: 3 mph. (NOT STOPPED)
-Minimum water temp: 22.5*F (On a 90*F day, that condition is probably met with a "cold" engine)
-Engine load: Some negative intake manifold pressure
So to answer your question:
We'll assume it's a nice warm morning and before you even start your car the water temp is above 22.5*F. So you hop in, start your engine (12 valves), you then put the transmission in 1st and floor it, you will be using 12 valve until you're going more then 3 mph and over 2500 rpm on the tach. As you shift from 1st to 2nd, if the rpms fall below 2500, you will return to a 12 valve operation until exceeding 2500 rpms in 2nd gear.
If you were at 70 mph in 3th gear (3500 rpm, 16 valve operation) and put the transmission into neutral (idle) vtec would unlock the secondary intake rocker arm and you would be in a 12 valve operation or "lean burn".
Look at the four conditions. If ONE isn't met, you don't get the additional valve. You get 12 valves for free and have to "work" for the other 4 valves.
Good?
ZO.
