Originally Posted by vrmouseyd15b
DOZFO ! You've got sick info! and you're right.
And, if you cold start and take off, you don't lean burn. you operate in 12v mode, unless you run beyond the low / high rpm crossover point, as DOZFO already mentioned.
Well, something new to me. I didn't realize lean burn was something within 12 valve operation. And I've research more since reading your post, I've got to change my PCV valve back to the original one - with no valve!
Thanks!
Civic VX Lean Burn monitor - Fuelly Forums
ZO.
