love the square bodies. owned an 81 for 15 years. had a 90 square body cab/chassis 1 ton, cut frame, added a long bed. put in a 4.3 and added a carb and it ran great.
the 700r is not known for heavy hauling but if you take it easy, it will last a long time. Corvette servo helps add some strength. the TBI will need the ECM.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
