Old 06-26-2014, 08:21 AM   #15 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Are low rolling resistance tires even available for this thing?
(trawling)
I guess so, there are so-called "SmartWay" tires for Class 8 so you should be able to find some thriftier tires.
I was thinking that the running boards were detrimental, you might have to do A-B-A to be sure. If they're bad you could use their hardpoints to install some skirting under your rockers.
