Old 06-26-2014, 05:21 PM   #5 (permalink)
oil pan 4
You might have been better off with a edelbrock 650 with vacuum secondaries being watched by a wide band oxygen sensor with gauge.
People really hated GM tbi on pretty much everything.
To make the 400r4 live in a 1ton you are going to want a transmission temp gauge and huge cooler for summer time. I would even recommend using the pure stock transmission cooler in winter and a huge cooler in summer. I dont think they like running cold.
The put in a manual lock up so you can run in 3rd gear with the TC locked up. Other wise they dont lock up unless in over drive.
