Old 06-27-2014, 04:25 AM   #6576 (permalink)
flores
EV Connoisseur
Originally Posted by MPaulHolmes View Post
What are the throttles of you 3? Well, of Flores and Duncan? So far I have 5k meaning zero throttle, and 0 meaning full throttle for jedsmd. Are the other 2 just 0-5k, where 0 means zero throttle, and 5k means max throttle? Also, do flores or Duncan have a contactor coil in line with the throttle? That's touchy business when dealing with current control. You really don't want the PWM to be ramped up to 100% while current feedback stays at zero, all because the contactor that is enabled through the throttle hasn't turned on yet.
If it's the same as the 500A and the 1000A, it will work for me.. no contactor
