Old 07-11-2008, 07:55 PM   #4 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Do one or the other, not all. If there's plenty of space up there then you don't need to add the ridge vent - that's best for when the space under the roof is occupied. If the entire attic is open, you can add just the turbine or the powered gable fan and have done.
Regardless, you will still need to add soffit vents.
