Old 06-28-2014, 10:10 AM   #11 (permalink)
Hondamate
wreck front - '98 honda civic hx
Originally Posted by jcp123 View Post
Maybe. If the honeycomb melted and is clogging the pathway, it sure could impact your mileage. If all it is, is a substrate material which has been "used up", it should have only a minimal impact on MPG. Downstream O2 sensors barely factor into your fuel trims. If you only got p0420 today, I doubt the computer is correcting anything enough to affect MPG.
Ok thank you
