Old 06-28-2014, 10:10 AM   #11 (permalink)
wreck front - '98 honda civic hx
Originally Posted by jcp123 View Post
Maybe. If the honeycomb melted and is clogging the pathway, it sure could impact your mileage. If all it is, is a substrate material which has been "used up", it should have only a minimal impact on MPG. Downstream O2 sensors barely factor into your fuel trims. If you only got p0420 today, I doubt the computer is correcting anything enough to affect MPG.
Ok thank you
Old 03-28-2015, 01:34 AM   #12 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Originally Posted by cbaber View Post
Is it the same readout of 0-125? The SG also has codes to enter that are listed as A/F Ratio Sensor 1 Bank 1, but when I enter those in no data shows up. Honda must not display that data, which is a shame because the actual A/F ratio readout would be more helpful than just the voltage.
Do you have similar experiences with lean burn conditions? I was a little worried at first because I have a cheap(er) O2 sensor. It game me codes and trouble until I figured out my non-OEM exhaust manifold was the problem. Switched back to an OEM setup and LB started working again, codes gone. The only thing now is that my EGR valve is broken. I actually have the connector disconnected from the EGR valve, so another interesting FYI, the LB works without EGR.
Actually the ECU does in fact report target afr and actual afr.
I can pull them up with my Launch Diagun tool.
I also get nothing when trying to program the afr xgauge.
I have had ZERO luck finding someone who has posted any good xgauge codes for our ISO9141 Hondas.
I wish I knew more about binary and crap.
I ended up returning my Scangauge as it was virtually worthless as far as x-gauges go. I can easily see when LB has engaged via the Ultragauge. I don't watch the rear sensor, I watch the front.
1998 LX with a full HX swap + VX transaxle.
Old 01-07-2016, 07:42 PM   #13 (permalink)
Rob
1hondaman's Avatar
Silver Bullet - '00 Honda Civic HX
Thumbs up HX Lean Burn Video Demo
Video Demonstration
I shot this video on cold night home from work. It demonstrates the different readings for different load conditions. Remember, low load = lean burn. The captions in the video explain what is going on.
http://youtu.be/r9GDerlnzOQ
CBABER 3-19-14
This video you posted is no longer there. Is it something you can re-load, I would like to see it.
Last edited by 1hondaman; 01-07-2016 at 07:45 PM.. Reason: Add date for ease of locating original post
Old 05-22-2016, 11:59 PM   #14 (permalink)
hi all i am using the torque pro app on my cell phone with the best bluetooth adapter that torque list. with the app i can read out the main lean air fuel sensor voltage in 0.230V to as high as 0.750V on a really cold night. when in lean burn in my 98 civic hx 5 speed i see numbers around 0.420V to 0.472V in normal crusing i range from 0.500V to 0.599V. when wide open throttle i see 0.600V and up. i can also read out a lot of live data and read can clear codes when driveing.
The Following User Says Thank You to 98hxman For This Useful Post:
MPGomatic (05-23-2016)
