your build looks better then mine, great job!
since you are a MPG Malta member you need some sort of designation of sorts on the car
Since the car will attract attention why not put some fun paint on? I painted the front with teeth on mine.... till last winter when the teeth started rusting so i changed it up
Its fun to see peoples reaction to each new paint job!
someone early on asked about taking the hatch off, I did on mine but now it leaks a bit at the joint. next time i might keep the frame of the hatch on and cut the rest out so i can still use the tail space.
