Old 06-29-2014, 03:52 PM   #42 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by California98Civic View Post
12.8 is a definitely a fully-charged reading on a starting battery. Does the Insight normally use the hybrid pack to keep the starting battery fully charged? (BTW, I hope you'll add your new ride to "team honda" as well.)
The 12v runs the normal electronics and the backup starter, which is only used if the IMA battery is dead or otherwise non-functioning. The IMA motor starts the car, both first startup and during auto-start/stop at traffic signals, so that battery isn't actually used to start the car. But yes, there is a DC-DC converter that feeds the 12v battery from the IMA battery. It may be that it's still figuring out the upper and lower charge ranges I suppose. It didn't drop this morning when I started it.
Did an antenna delete, and drove back to Tallahassee from Jacksonville. I had my brother in the car and he insisted on blasting the A/C, "It's 100F, whaaaaaa". Trip was around 62MPG at 65-70mph. Thinking of doing an upper grille block and rebuilding the missing sections of belly pan as my next mod. Cleaning the EGR passages didn't give a noticeable improvement in economy, though it feels smoother when in lean burn.
