Old 06-29-2014, 08:09 PM   #36 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Old Mechanic View Post
I like the scotch brite pads on an electric drill. Looks like you used one on the last step.
Some urethane primer and block her down.
Just picked up a snap on air brush today at a yard sale, never tried one.
regards
Mech
Yep I used a 3m scotch brite scuff pad on a 6" DA sander.
Last night I sprayed one coat of PPG DP90LF epoxy primer on the hood and bare metal spots and then this morning sprayed 3 coats of some Urethane K36 Primer Surfacer over the top of all the worked areas.
Now i will let that set until next weekend and begin the primer blocking stage.
EDIT:
The black spatter paint is SEM Guide coat.lol
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Daox (06-30-2014)
