Old 06-06-2014, 01:57 AM   #31 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
71 Camaro - '71 Chevy Camaro
White Pearl - '26 Toyota Prius SE
I forgot to mention i have FP filters also.
Pressure Gradient Force
The Positive Side of the Number Line
Old 06-06-2014, 08:55 AM   #32 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 31.64 mpg (US)
Felicia (retired) - '09 Toyota Prius Base
90 day: 49.47 mpg (US)
You CAN have it all! Mileage, power, looks.
I should ship my dropped-valve 4g64 to you, your work looks fantastic.
The Following User Says Thank You to elhigh For This Useful Post:
pgfpro (06-06-2014)
Old 06-06-2014, 08:32 PM   #33 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Thanks for the kind words!
If you were closer I would be glad to help.
I'm starting to realize it might be closer to the end of Summer before I get this thing back on the road again.
I have to admit this is by far the hardest thing I have ever done. Trying to make a high HP fast car that still gets decent mileage is a lot tougher then I thought it would be. Plus one of my biggest problems is making to many changes all at once. I'm fighting right now wanting to pull the engine back apart to change up the compression.
So I'm going to button up a few more engine items this weekend, then its time to get on the body and paint. This should get me a little more motivated?
EDIT:
All the engine work is done time for some body and paint work!!!
Old 06-28-2014, 12:53 PM   #34 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Body work begins!!!
I have the passenger side door all pulled out with the first stage of body filler applied. This door should of been replaced, it took me about 3 hrs on the caved in lower dent alone.
Today I should have all the passenger side body worked done plus the hood.
The hood had three paint jobs on it. Most of it was poor chip repair from the previous owners.
This pic is the hood with all the edges taped so chemical stripper doesn't get around to the under side and make more work.
First application of stripper.
First staged scrapped all the lifted paint off and wiped dry.
Second staged of paint stripper
Second staged all scrapped and dried. Were finally there. Most of the metal is exposed.
This pic the small amount of paint that didn't come off with the stripper gets sanded with 80 grit using a 8" buffer soft Velcro pad.
The hood should be around a pound less now.
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
Joggernot (06-28-2014), user removed (06-28-2014)
Old 06-28-2014, 01:20 PM   #35 (permalink)
I like the scotch brite pads on an electric drill. Looks like you used one on the last step.
Some urethane primer and block her down.
Just picked up a snap on air brush today at a yard sale, never tried one.
regards
Mech
pgfpro (06-28-2014)
Old 06-29-2014, 08:09 PM   #36 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
regards
Mech
Yep I used a 3m scotch brite scuff pad on a 6" DA sander.
Last night I sprayed one coat of PPG DP90LF epoxy primer on the hood and bare metal spots and then this morning sprayed 3 coats of some Urethane K36 Primer Surfacer over the top of all the worked areas.
Now i will let that set until next weekend and begin the primer blocking stage.
EDIT:
The black spatter paint is SEM Guide coat.lol
The Following User Says Thank You to pgfpro For This Useful Post:
Daox (06-30-2014)
Old 08-12-2014, 05:33 PM   #37 (permalink)
Still sanding?
Old 08-12-2014, 06:17 PM   #38 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Originally Posted by Ardent View Post
Still sanding?
You know it. lol My fingers are starting to bleed!!!
Well here it is as of now.
First coat of base coat over black sealer. The fenders are still in sealer in this pic.
Third coat of base on all the parts.
Third coat of base coat on door.
Clear coat.
Joggernot (08-12-2014)
Old 08-13-2014, 12:34 AM   #39 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Here it is as of tonight.
Hood is now on, with the rear spoiler and upper side trim installed.
As you can see the "side out race exhaust is done with the lower molding still needing cut and painted.
Its starting to take shape but it has been a very long process with a whole lot more body work then I ever would have thought.
I'm now working on gathering parts for the Hybrid system. I might have just got the the ultimate hook-up... with a system that will be donated.
Old 08-13-2014, 03:52 AM   #40 (permalink)
For how long have you been painting cars? I have been talking about covering my Civic with Plasti-Dip since before I bought her. I do not have any idea why there are so many black cars in Arizona! My paint is terrible, too, and a fender is banged up. I could pay to repaint the car, but I understand that it would cost at least as much as I paid for the car!
bio fuel, lean burn, turbo compound
