I wouldn't, you should not need to, but if it makes you feel better then just a finger spreading it around, just enough to make it look wet. It would be different if you did not use a gasket, but then the oil pan would be different and have a channel to put the rtv in and you would just lay a bead and slap it on. Use the stickines of the rtv to stick the gasket to the block, using a bolt to line up the holes. Put every bolt in the pan before you tighten any of them and start in the middle, easy does it.
regards
Mech
