Old 06-29-2014, 10:30 PM   #137 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Question Valve cover bolt grommets (install trick)
"Maintain before mod"
If I will ever have a full undertray (bellypan) I need to resolve persistent fluid leaks in the engine compartment.
So today I replaced the two valve cover bolt grommets that have been leaking. They visibly leaked a little oil regularly, but they might have been leaking a lot when the engine got really hot on the 100-150 mile trips the car sometimes does.
1. Here is one of the OEM bolt/grommet/washer combos:
Notice there is a bump on the bolt neck. It will prevent removing the grommet. So you have to cut the grommet with shears:
2. The grommets, cut, and the washer, which need not be cut, and the bolts:
The slightly tricky part is installing the new grommet.
3. To install the new grommet, you first clean the bolt. Then lubricate the it and its threads. Finally, you need a method to push the grommet past the bulbous section of the bolt. I decided to use a 3/4 socket to contact the grommet, and a 3/8 deep socket as a head to gently hammer on until the grommet slipped into place. Was amazingly easy, but the FSM was not helpful on this point. A pic of the results and the stuff I used:
4. I then MADE A MISTAKE that I wouldn't mind some advice on. The factory service manual has torque specs for the bolt in the valve cover. I tried to meet those and over tightened one of the two bolts, definitely compromising the threads, but apparently not so badly to produce an oil leak when I took the car for a long test drive to see if it would leak. Here it is in place:
I imagine I'll probably have a heli-coil adventure in my future sometime, but do you think I can leave it alone for now? I can't loosen it with my fingers and it has no visible play. Just watch for leaking? Ugh. I tightened the other bolt with a simple ratchet and it seated perfectly. Any thoughts?
Also:
I resolved the coolant leak a few days ago simply by remaking a seal on the upper rad hose. No thermostat needed, apparently. Also bled the coolant. Old stuff on the left, new on the right (yikes):
ID:	15284   Click image for larger version
ID:	15285   Click image for larger version
ID:	15286   Click image for larger version
ID:	15287   Click image for larger version
aerohead (08-23-2014)
