Thread: Tested rpm-mpg
Old 06-29-2014, 11:58 PM   #23 (permalink)
vrmouseyd15b
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
Originally Posted by Cobb View Post
vrmouseyd15b, whats the check engine light for? Some cases that can cause the computer to not allow lean burn if equipped and cause the fuel system to run at a default afr rate vs relies on the o2 sensor(s)
No check engine light. that's my "lean burn indicator" / happy light. I'm on a jdm p2j series ECU. they should all have an "econo (lean burn)" light. I think it's at pin a30, and I'm sure it's a switched ground. I bring SWITCHED 12V POWER to one side of the bulb, and pin a 30 to the other side of the bulb. here's a shot with KEY ON, ENGINE OFF:
EDIT: When I said "they", I meant the p2j family of ecu's but - I'm not totally sure
my "happy light / econo light" Is above 4500 rpm, Check engine light is above 5500 rpm. I hate seeing the check engine light because you are right, check engine light = no lean burn!
