Recording your MPG on the go
I've been looking at a few different fuel logs on here, and have found that many people have had the problem at one point or another of the MPguino losing power and resetting their distance, or someone else resetting the trip meter.
Other than the obvious part of writing it down on a piece of paper, I use 2 different android apps. Both are FREE
The first one I found and use it called Fuel Calculator. The icon looks like a circular fuel door. It works well and I have never had a problem with it.
The upgraded version of that app is called Mileage, and the app icon looks like a black gas pump on a yellow background.
Both apps work well one you get them set up.
Just thought I would try to help some people out
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
