it looks like you have a training manual...its kind of vague.
from all i can tell, you may want to put a kill switch on #11 ignition wires or #13 fuel injectors or #6 fuel pump. however, i strongly suggest AGAINST from tapping into any wires that go into the ECU.
Fuel pump #6 will not yield the best results because it still takes 3-5 seconds before it completely shuts off, therefore, it spits unused fuel into the combustion chamber.
However, if you're able to find the SERVICE MANUAL...it would be a lot more helpful in looking for alternatives on where to install your kill switch.
