Also, calicivic, if you don't mind, can you compile a list of everything that could be leaking on the tranny? I'm just gonna replace them all at once so another doesn't start leaking in a year.
Also, I have officially gone through 1qt of oil since I bought the car. It doesn't burn oil mind you, it leaks oil. Also I changed the distributor gasket and had a timing belt job done so I'm sure that took like 1/5-1/4 a quart but Yea.
Ok guys, another thing, what all could potentially leak oil on a car? From my very limited knowledge the oil pan, head gasket, oil drain bolt(which is leaking), camshaft, rear main seal, distributor gasket and valve cover gasket right? What else is there?
