Old 07-10-2014, 03:45 AM   #33 (permalink)
RustyLugNut
Really?
With all that science why is it in the unicorn corral?
I think it has something to do with being the absolute best case scenario mod for A-B-A testing and it still can't produce results.
How sure are you of that?
You do realize the Youtube experimenters leave much to be desired as far as scientific basis and engineering prowess.
And you do realize it is complex. It is not the simple scenario for an A-B-A test as one can run an engine so lean with hydrogen that turning off the hydrogen stream results in a no-run condition. Even the stoichiometric burn has to be adjusted for with timing changes. Stop the hydrogen stream and you must reset the timing advance or the engine lags and smokes.
