Old 07-10-2014, 09:52 AM   #20 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
I thought the general consensus here was that an airdam was good for 2-5%; even the modest 2% improvement would be good for about another mile per gallon. So while you're being conservative with your numbers, I daresay you're being TOO conservative.
Don't forget the savings snowball: if you don't need as much power to push your car down the road, then you're running the engine at a lighter load, less stress on moving parts, longer service life etc.
In terms of dollars per year, I think making the car go an extra few years is a savings that is both very real and very difficult to quantify.
