Originally Posted by California98Civic
The list is pretty short:
Input Shaft Seal (tranny must come off).
Driver side drive shaft seal
Passenger side drive shaft seal
Shifter linkage seal
Tranny oil drain plug
Tranny oil fill plug
Oil, of course can flow around the engine parts and the block, however, so be very sure that the leak is coming from the transmission by eliminating other possibilities, other seals, elsewhere on the engine that might leak oil that eventually drips off the bottom of the block or transmission. Distributor seal? Oil filter seal? ...I'm in that process right now.
I'm not very confident that my tranny is leaking... I took the fill plug off and it's still full of fluid... And I looked and I can't find a single leak on the entire tranny. The main oil leak is right under the distributor, I already replaced the distributor gasket so it isn't that, it's right under that is where it's leaking..
