Old 07-10-2014, 06:13 PM   #25 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by xntrx View Post
...A HF trans wont fit your car (mounts are the issue, cable issue can be solved), nor can you swap the guts. I you could, I'd run it, since I have one.
That's interesting. Thanks. Here's a guy on EM who says he paired an 89 HF trans with a VX engine in a fourth gen Civic body. So he would have had the stock fourth gen mount to match the HF transmission, I guess. I wonder if he had to fabricate mounts for the VX engine or if the engine side mounts were the same 4th to 5th gen?
